Online: Humbug, Ultramick
Dyna Seats
  • braando
    braando
    Hi, i need some help with an 09 Lowrider........i picked up a 2010 wideglide seat and pillion on ebay for a good price......my idea is to use the solo but turf the pillion seat and get a wider pillion through HD.......problem is.........my guard now has four bumper rubbers still stuck to it.......i will probably stick them on to my original just in case i want to use it but how in the hell do i get them off the guard..?   someone told me heat will do the trick but before i try that i was wondering if anyone here has some eperience with this....also..i have to move the threads in the guard for the screw to hold the seat........it has me confused.......
    brian.......
  • braando
    braando
    Many thanks for that Zag........you just solved my main problem mate........originally i was going for the barebones........but came upon a new unwanted 2010 wideglide single for $60....couldn't pass it up.........how did you remove those rubber bumpers on the guard...?     did you have those too........?
  • SuperGlide
    SuperGlide
    they are just Sticky back things.
    Pull the fuckers off as best you can, then heat etc if you want. I personally just smashed it with a bit of Metho and stuff and WD40 and anything else I could find with a cloth and some elbow grease. Very easy that one, the tank badges are harder, and refelectors on fork legs are real fun too.
    I bought a C&C seat, you can order custom style to suit from the states see pic below.
  • braando
    braando
    Thanks heaps for your help.............!           job done
