Online: B1ack
Short Z Bars for 2010 wideglide
  • ==ShaDoW==
    ==ShaDoW==
    Hi all looking for some black Z bars internal wiring (set up for stock control) that are about 6" to 8" inch  anyone have any ideas most the ones round are 1' centers (isnt the WG 2010 1 1/4"?)
    thanks in advance
  • ==ShaDoW==
    ==ShaDoW==
    would putting the bars above on stock risers cause issues? to much leverage on risers? any ideas?
  • ==ShaDoW==
    ==ShaDoW==
    As a side note does anyone know how much slack is left in cables from factory for the 2010 WG ?
