Online: Soapbox2627
No Spark 2003 Carby RK
  • Floss
    Floss
    Hi all
    just tried to start the bike this morning - she no go.  No spark on either cylinder. Here's where I;m at after checking terminals/connections etc  The only work done recently was to replace the starter motor clutch.  The only issues I recall was the bike died for about 20 seconds a couple of months ago (once only) with engine at high reves as I overtook a truck.  At the time I put it down to a bit of gunk in the fuel but now I'm wondering.
    Battery good and motor turns over fine
    Security/blinker module appears to work ok. (Blinkers, arm/disarm, indicator in speedo on off.
    Turn ignition on and engine check indicator goes off in about 4 secs
    Engine kill button working ok (engine won;t turn over in the off position)
    Headlight bright, neutral light on
    Could you help me with the following questions
    If the engine management indicator in the speedo goes out approx 4 secs after the ignition is turned on, does that indicate that the self check of all the engine sensors is complete or just a self check of the ignition module?
    Is there a 'known fault' or likely suspect  with this model?
    Will the local HD dealer diagnostic tool usually identify faulty sensors?
    I expect there are only likely to be a couple of sensors that would actually prevent the engine from running. (crank position, lean angle and I believe thei is an 'enable'  from the security module etc)  Are there tests and checks I can do.  (Ive got a good digital multimeter etc)
    Will I be able to go for a ride at 8.00am tomorrow?
    Any tips/advice appreciated.
    Floss
  • jaxdwg
    jaxdwg
    Try going here and join, they have some pretty smart critters here http://www.hdtalking.com/dyna_models/
  • Floss
    Floss
    Thanks for the tip jaxdwg I'll check it out
    Floss
