Dyna Lift Kit
  • rider
    rider
    98965-99 Twin Cam 88 Lift Adapter
    For use on '99 and later Dyna models when lifting the Motorcycle by the frame. ($38.00)
    Seeing as there has been a bit of discussion about lifters and lift kits in the last few months I thought I'd throw up a couple of pics of the H-D lift kit for Dyna's,
    for those interested.
  • WAGlide
    WAGlide
    Got them & they are great. I took the bike for a blue slip & totally forgot to take them off :)
    Hey rider,
    Thanks for the letting us know about the adapters.
    I will be going to get mine tomprrow.
  • Mainey88
    Mainey88
    yep the adaptors work well saves rooting around with bits of wood and have the same lift x repco on special.
  • Firey
    Firey
    I just phoned Repco here in Batemans Bay - The Lift T2151 is $281 not on special - still 20 years behind here!!
  • Mainey88
    Mainey88
    just hang in there firey, they come on special a couple times a year, around 50% off
  • Thomo_Baca
    Thomo_Baca
    Where are they available from?
  • wilso
    wilso
    kool... ive steered away from these lifts in the past because of the difficulties associated with lifting my wideglide, now im off to get some of these babies and then a lift, cheers for the info Rider.
  • Firey
    Firey
    Cheers - I will wait for the 50% off, thanks Mainey
  • wilso
    wilso
    yea no worries there mate mines not lowered.... cheers
    So you all start off with the bike on a plank (like the first pic shows)? I'm still amazed they fit under. I'm sure the wood I use is thinner than that and it barley goes under....and I don't think my bikes (streetbob) lowered.
  • 78gold
    78gold
    I already have two planks that I wheel bike onto to get lift under as just no clearance.
    These look ok but would probably need thicker planks to get the clearance.
    Can be fun sometimes sitting on the bike and operating the lift with me right foot.
    Ride Safe All
    Nigel
  • Aussie XB12SS
    Aussie XB12SS
     I use the Harley Lift & still won't go under.
    Need to push the bike onto timber about 1" high first.
    1 year ago
    Are these still available?
    1 year ago
    cheers.... I'll just print some tbh.  way faster and cheaper.  Plus they are american.... and we are on the verge of war with them so they can go f. themselves.
    1 year ago
    They are hard orange rubber you just cut them to suit your frame I don’t use the black plastic bits
    They work a great on  my softails when I use them , I got mine years ago from Harley Haven
    Like $45  back than
    1 year ago
    cheers,  already printed a set and they are under the bike working a treat helping me swap out the rear rotor for one thats JUST A TAD ABOVE MIN SPEC
  • flstc08
    flstc08
    1 year ago
    Quoting tussuck on 13 Feb 2025 08:30 AMedited: 13 Feb 2025 08:40 AM
    G'day,
    I think they are doing that already.
