Online: Humbug, Ultramick
Postage cost from U.S
  • maxdog
    maxdog
    Can anyone give me an indication of postage from H.D Chicago. Looking at buying some gear but they wont tell the postage until its being shipped. Don't want to order and then be stung with crazy postage.
    Thanks Maxdog
  • kingkingking
    kingkingking
    I bought an oil cooler and a few other bits, postage was $52 US.
    Landed I saved $350 total on the cost of buying the bits at frasers.
    they will ring you with the price first if you ask. they are really good blokes in my experience.
  • Bobtail
    Bobtail
    M&M give ya a quote for the bits and the freight in USD,.....They usually send via Fedex....I have got quite a few bits from them with no probs at all....Normaly use paypal inc currency conversion...
    Bt
  • solo
    solo
    mate i have bought 1000's of dollars worth from chicago hd and the most i have paid for frieght is 50 us, the problem is the aussie custom's, spend over a grand(aud)and the will hit you hard, eg, bought $1600 stuff and had to pay $265 excise
  • Sparra
    Sparra
    Some of the places wait until you get to the checkout and you tell them where it's going to be sent,once that is done a total is tallied up just before you finalise the deal so you have a choice to pullout or continue...
    Good luck with it...Sparra
  • 2005 FLSTFI
    2005 FLSTFI
    just a heads up, I was sent some gear from Chicago HD  a few months ago, they were great but they use DHL & they were fucked.  Clowns lost my order & didn't know where it was even though internet tracking said it was in their distibution centre. It took them 3 days to find it.
    If you use Chicago HD get them to send it Fedex, maybe a bit more expensive as someone has said but alot more organised.
    I have used M&M Cycles a quite a number of times (about 7) & they use Fedex and I have never had an issue
  • jacks
    jacks
    Purchased a Deerhorn (for Roo's) from J&B once, item was US$65, turned out to be chrome plated plastic, lasted only 6 months and cost me landed AU$ 145 and I had to go to the bloody depot to pick the barstard up myself...the pricks...I complained and was told that I would get a big discount off the next purchase (15%)....what next bloody purchase???
  • kiteman
    kiteman
    Maxdog, looks like you're fairly new to this forum. I have bought many many thousands of bucks worth of stuff from Chicago HD and never been ripped off on anything. They are a serious outlet with a shitload of staff. Just trust them and I'm sure you will be happy. The 20% discount will cover a fair bit of your freight costs anyway. Keep the total under say $900 Aus and you should be fine. Even if you had to pay GST you will be miles ahead. If you order say one item worth $100 then you probably won't save anything. If you order several then it will pay off better.
  • Peter L
    Peter L
    I just received a chrome rack and 2 T SHirts from J&P Cycles, postage was $50................Got a similar sized package from Real Hog.com and postage was only $20..........Keep shopping around
  • kiteman
    kiteman
    Australian domestic parcels go on volume. International parcels go on weight. Five grams can take you over the kilo weight. Size is irrelevant.
  • SuperGlide
    SuperGlide
    depends on size of ur shipment, USPS is the postal service and very reasonable.
    I've shipped with Chicago a couple of times and they have always been fine, prob got a 20% mark up on there but nothing scary.
  • maxdog
    maxdog
     Sorry for the late reply, thanks for the tip. Have ordered from Chicago HD and saved approx $400
    Cheers.
