will 2010 fatboy rims fit on a 94 sporty
  • bfcaust
    bfcaust
    Hi all
    Need some help as i have been given a set of 2010 fatboy rims and was wondering if they can be fitted to a 94 sporty.
    Any advice would help before i start to take things apart.
    Thanks Mario
    Yes and No, The Back wheel will go on if it's a 150 but you will have to change the Bearings to 3/4, To fit the Front Wheel, you need a Wide Glide Front End
  • mato_h
    mato_h
    dosent the 2010 have 200 rear on it ???? i know my 07 has a stock 200 rear
