my front caliper wont close
  • sargeheritage
    sargeheritage
    hi fellas need help ,i have bought a new  master cylinder have been bleeding for hours i removed the caliper and opened it up to remove air ,now there is a gap of 10mm from the disk and pads and they wont close up , no mater how many times i bleed it ,what am i doing wrong ,thanks in advance
  • Sparra
    Sparra
    Do you have the right fluid???
  • sargeheritage
    sargeheritage
    dot 5 fluid is recommended for my bike thanks dave i will give it a go cheers mate
