Online: baldy1450, Wanderer57
Shots Fired!!!
  • Hipshooter
    Hipshooter
    I've got a 97 Fatty. Of late, until the bike is hot it backfires and farts and coughs and carries on. I let is warm up for about 5 min before taking off, but still sounds like someones getting shot whenever I throttle on.
    Recently had it serviced and had new plugs put in.
    I'm thinking maybe points? Any ideas?
  • clarkie
    clarkie
    has 97 got points thought they were electronic,if its been converted try changing the condensor,had one go on me and it was only a couple months old was doing what your bikes motor is doing,only my humble opinion,
  • Hipshooter
    Hipshooter
    I am an idiot , yes it has elect ignition (Screamin Eagle 2). Should read and comprehend what I write before I post.
  • Chips
    Chips
    Sounds like carb problems, maybe the accellerator pump that squirts extra fuel in as you throttle on.
  • Evo
    Evo
    Check manifold for leaks. Common enough problem on evo's and easy to solve. Bet it also stumbles a bit when you back it off.
  • jim76
    jim76
    Have you cked your plug leads? one may have a high resistance till it warms up giving you a miss fire under load. hope it helps.
  • monarofan
    monarofan
    hey Hip, swap out your new plugs for some good old ones, see if that works, i say this because i had a sporty with brand new plugs, NGKs i think, no klms at all, the bike sounded like a firing squad when you reved it even a little, put some good old plugs back in and it ran like a top, no backfiring at all , was then told by a reputable shop that once plugs foul , new or old , they're stuffed, so in this instance that theory was correct
  • Hipshooter
    Hipshooter
    Thanks for the feedback guys. I have checked the exhaust and found that the nuts on the rear pipe were loose. It probably gave a coupla mm clearance at the manifold. Once that was done it didn't seem to be as bad.
    I have ridden it since and still plays up, but not like before.
    Andrew, I will try some older plugs tomorrow and see how it goes. Tks for the tip.
    Watch this space.........................
