I am not a big fan of the 21" front wheel on my FXSTC and was gonna change it over to a 19"...Before I spend the dollars I was wondering if there are many other options...Has anyone put anything else on to replace the stock 21"..
Cheers...Sparra
Recommend the 19 mate, have done it to 2 wideglides over the years, improves handling and grip, not hard to lower the guard to suit.
Check it out on 85 Wideglide....
Burto
Great look Burto...Did you buy the rim and spokes and use your original hub or did you source a complete wheel???
