Online: beaglebasher
Ultra 03 SE203
  • CHARLIE
    CHARLIE
    Have been given a new set of 203 cams to fit to the Ultra what i need to know is will i get away without doing a download again, as it has air cleaner and exhaust done only,reason it has no passing speed 2 up and i am hopeing the cams will give me that bit extra,don't want to do any major motor work just cam at the moment.Charlie
  • CHARLIE
    CHARLIE
    Tks for the replys and yes 2 up it is a barge scotty you want to see it in the wet,it has 91 thou on the clock so i guess i should do the lot and be done with it.Thinking of 1550 kit yes or no.Tensioners are fine still the same ones  you send to me scotty.Will have a look at them before i leave for Mt Isa Hog rally in August.I guess in the long run it's not that bad to start your run a bit early to pas still get around. tks Charlie
