Online: baldy1450
Fitting V&H Pipes
  • Purnong
    Purnong
    Ok, Just got a new set of V&H Q-Series Double Barrel pipes
    Was just mucking around in the shed trying to fit them and it looks like the flanges dont line up properly on the heads
    The back one fits fine but the front is about a half inch too short
    Anyone got any tips to fitting these things? Does the footpeg have to come off for fitting or any other tips would be good
    They are the right part number for the bike so I'm sure I'm missing something
  • GREG
    GREG
    A few of us had the same problem fitting a set of supertrapps to a rockerc. What should have been a half hour job took us 3 friggin hours. It took a lot of jiggling around and a bit of gentle persuasion with a punch on the flange to line everything up. Different pipes I know but it helped having two people. One lining up the rear and the other on the front.
  • Purnong
    Purnong
    Thanks greg
    Just got it done
    Had a mate come over that is a bike mechanic and he had them on in 5 minutes, Just gotta pull and push in the right places
    Will fit them up properly tonight
