help needed getting rear fender off.
  • berms
    berms
    Hi Fellas, this may sound stupid, but I can't get  the rear fender off.... I have alsready busted my HD 8-in-1 screw driver trying but these star-centred "fasteners"  that hold the fender on are unbelievably tight....
    Am I missing something?  and yes I do know that lefty is loosy and righty is tighty)
    Thanks for any help.
    You are using the right tool for the job, right? Do these "star centered" bolts need a security bit?
  • PigironBob
    PigironBob
    They probably need some heat on them, some of them are glued in.
  • kickinon
    kickinon
    my 06 had that blue lock stuff on the bolts, tightest bolts ever ,need a good fitting tool , care & leverage..
