Online: Wanderer57
install of new sideshots and some other stuff.
  • ==ShaDoW==
    ==ShaDoW==
    Hi all I have my new black side shots for the FXDWG, but i am unsure of what to do to install them, I am happy putting pipes on etc but the sensors have me worried as this is the first fuel injection bike I have had.
    So what do I do with this stuff?
    What do i do with this?
    And do i just unscrew these and screw them in my new pipes?(new pipes have holes for two sensors)
    Once I have pipes sorted I will do the TTS and air cleaner which i also have now ready to go.
    thanks in advance
  • ==ShaDoW==
    ==ShaDoW==
    thought that was the case where do i unhook the active exhaust at the top bit?
  • Rowdy
    Rowdy
    Shadow you disconnect the wiring plug from the active exhaust valve control unit then unbolt the whole unit ,it stays connected to old exhaust via the cable .
  • ==ShaDoW==
    ==ShaDoW==
    thanks rowdy, would you happen to know if i need to turn this off in the TTS before I ride with the pipes on?
    My plan is to put pipes on and ride then do air cleaner and TTS will this work out?
  • ==ShaDoW==
    ==ShaDoW==
    pipes all done now i got to read up on the TTS so  I can put air cleaner on and retune.
    PS dont mind the mid controls and gear shift on the same side I am a amputee so I shift both with right side :-), need to get a new mid brake now the stock pipe is not on the way so I can custom cut and paint it to be where my heal sits.
    PSS I never put the BCT baffles in yet I am going to ride it and see how it goes for a while.
  • toxic
    toxic
    pipes look the goods old m8... I put shot shots on my Nightster the day I picked it up.... just a note of warning though... don't ride it much until you retune it.... do the air & tune so ya only have to do it once....
  • ==ShaDoW==
    ==ShaDoW==
    air cleaner on loaded ae176 map not to bad havent done v tune yet.
  • ==ShaDoW==
    ==ShaDoW==
    done 2 vtune runs seems ok to me I will do 2 more I think next weekend, still getting a bit of popping but open pipes (stock baffles) i would think you will always get a bit.
    quick question once i have done the vtune all I do is blend files then put AFR and PE back to orig value? I leave the CLB at 720 yes/no?
    Also would a CLB of 720 for front and rear give me more popping than a lower one?
  • ==ShaDoW==
    ==ShaDoW==
    Put my BCT baffles in last night, sound has change quite a bit not so harsh now also popping has gone (:-0) will do the vtunes today and see how I go, also going to try a lower CLB as 720 seems rich to me, to much "soot" in pipes would like to get them more "grayish"
