Decisions Decisions. Standard or Custom?
  • Frnkstn
    Frnkstn
    Hi guys. I am in need of some advice.....! I have my eye on a New Softy Standard...2009, or I can go with the Custom....again 2009.... Both brand new.
    What are the pros and cons here? I would like to customise the standard, but take my time, BUT, would I be better off just to bite the bullet and go the Custom?..... about 5K difference.
    What do you guys suggest?                 Thanks....... FRANGA !!
  • Bobtail
    Bobtail
    As Ando indicated the prob with the custom is that ya still hafta spend at least another 5 grand to get pipes, cam, bars, tuner and air cleaner.....then ya gotta upgrade the shocks put in a 103-107 kit and heads etc..... and before ya know it ya bike owes ya 40+k......
    I chose the standard because it gives me the flexibility to make changes without breaking the bank....
    Whatever choice ya make...good luck..
    Bt
  • ductor
    ductor
    Mate,
    Get the FXST, It has the same shit metal in the same place as the custom , wheel spacers, indicator bolts, torx bolts. When they loose their lustre (after the first time you get caught in the rain) you won't be quite as broken hearted. Then you can ride it and not feel guilty about the dirty chrome.
  • Taffymarsden
    Taffymarsden
     Can't beat that smooth wheel for looks.
  • Burraburra
    Burraburra
    Hey Franga,
    Is ya head spinnin yet
    Went through the same thing mate - just take ya time and loook and re-look at them in the flesh.
    I got the softail 2009 last december - wont tell you what one - but I made my mind up eventually.
    Good luck mate
  • Frnkstn
    Frnkstn
    Thanks for the replies guys. Gonna go with the Softi Standard option.  back soon...FRANGA !!
  • Surly
    Surly
    Another standard with wheel option and chrome kit. I prefer the black engine but the chrome kit on the silver engine makes a huge amount of difference for about USD$770.
    Surly
  • Frnkstn
    Frnkstn
    Okay.......Whacked a deposit down on a 09 Standard that has all the bling already attached..........Will post photos soon.Ride safe guys..FRANGA !!
  • ductor
    ductor
    Roll on Franga
  • Frnkstn
    Frnkstn
    Yeah
  • MIKER
    MIKER
    I really like the STD , but when i put my coin down $$ there was no other way for me "Custom" all the way . i wanted the black Donk , chrome engine cover's  , chrome oil tank , smooth wheels ,  etc etc etc , being i would have spent equal or more to make my STD look like a Custom the choice was easy for me & in the end a STD isnt a Custom "Enjoy either the STD or Custom both are great" . .  2 cents
      Line 1 Custom / Line 2 STD
    DIMENSIONS
    Length 2410 mm 2400 mm
    Seat Height
    Laden N/A N/A
    Unladen2 705 mm 720 mm
    Ground Clearance 150 mm 130 mm
    Rake Steering Head 32.3 ° 32 °
    Trail 127 mm 147 mm
    Wheelbase 1700 mm 1635 mm
    Fuel Capacity 18.9 L 18.9 L
    Oil Capacity 3.3 L 2.85 L
    Weight
    Dry Weight 303 kg 297 kg
    Running Order 317 kg 309 kg
    Luggage Capacity
    Volume N/A N/A
    Weight N/A N/A
    POWERTRAIN
    Engine3 Air-cooled, Twin Cam 96B™ Air-cooled, Twin Cam 96B™
    Displacement 1584 cc 1584 cc
    Bore x Stroke 95.3 mm / 111.1 95.2 mm / 111.1 mm
    Engine Torque EEC/95/1 EEC/95/1
    Engine Torque4 Nm @ rpm Nm @ rpm
    Fuel System Electronic Sequential Port Fuel Injection (ESPFI) Electronic Sequential Port Fuel Injection (ESPFI)
    Compression Ratio 9.2:1 9.2:1
    Fuel Economy
    Fuel Economy City 6.72 l/100km 6.72 l/100km
    Fuel Economy Hwy 4.36 l/100km 4.36 l/100km
    Primary Drive Chain, 34/46 ratio Chain, 34/46 ratio
    Gear Ratio (overall)
    1st 9.31 9.31
    2nd 6.453 6.453
    3rd 4.793 4.793
    4th 3.881 3.881
    5th 3.306 3.306
      2.79 2.79
    WHEELS/TYRES
    Wheels
    Front5 Chrome, Profile Laced Aluminum Chrome, Steel Laced
    Rear5 Polished, Slotted Disc Forged Aluminum Slotted, Forged Polished Aluminum Disc
    Wheel Option Chrome, Profile Laced Aluminum (rear) N/A
    Tire Size
    Front MH90-21 54H D402F MH90-21 54H
    Rear 200/55R17 78V D407 200/55R17 78V
    ELECTRICAL
    Instruments Tank-mounted electronic speedometer with odometer, time-of-day clock on odometer, dual tripmeter, fuel gauge with low fuel warning light and countdown feature, low oil pressure indicator light, engine diagnostics readout, LED indicator lights, 6-speed indicator light Tank-mounted electronic speedometer with odometer; Time-of-day clock; Dual resettable tripmeter
    Indicator Lamps6 High beam, front fender running lights, neutral, low oil pressure, turn signals, engine diagnostics, security system (optional), 6-speed, low fuel warnings High beam, neutral, low oil pressure, turn signals, engine diagnostics, security system, 6-speed, low fuel warnings
    Reverse Function N/A N/A
    CHASSIS
    Brakes 4-piston front and 2-piston rear 4-piston front and 2-piston rear
    Parking Brake N/A N/A
    Lean Angle
      Chrome, staggered shorty exhaust with dual mufflers Chrome, staggered shorty exhaust with dual mufflers
    COLOUR OPTIONS
      Vivid Black
    Scarlet Red
    Red Hot Sunglo
    Two-Tone Flame Blue Pearl / Brilliant Silver Pearl
    Vivid Black Brilliant Silver Pearl Flame Blue Pearl
    PRICING1
    MSRP
    Solid Colour $32,080 $27,960
    Pearl
    Two-Tone $32,580
    Custom Color
    Security
    Wheel Option
    (Solid Colour)
    $32,580
    Wheel Option
    (Two-Tone)
    $33,080
    ABS Option
    Reverse Option
    Cruise Control
    California Emissions
    Freight
  • Frnkstn
    Frnkstn
    Thanks Miker.......I've settled on a 2009 Standard with a heap a bling. Picking it up tomorrow.....Will post pics. I've just come off a Yammy XVS 1300. Great machine. Sold it last week to pay for the FXST........   I'll be back on Friday.........................................  Franga !!
  • matt08
    matt08
    good choice franga!
