Online: John.R
Anti Speed Camera
  • wildgoose71
    wildgoose71
    Just highly polish the number plate on the bottom half only - I mean really polish the bugger til it sparkles.
    Don't do the whole plate, only the bottom half, keep the top half as dull as possible.
    Supposedly when the flash goes off the glare from the shiny bottom half blocks out enough of the plate to make it unreadable. Apparently it is important to do the bottom half only so that if they adjust the image to get a clear pic they will still not be able to read the full plate.
    I can't say if it works or not because I'm not gonna race through a camera to find out but if I go through one that flashes and I never get the fine I'll let you know.
    If you drive a 4wd or F100 just fit your front number plate over to the left side of the roo-bar and bend the outer edge slightly - just enough to curve the plate so the camera won't get the whole number - I know a bloke that reckons he has been through dozens of cameras and still no ticket using this method. Coppers have also pulled him over and never taken issue with the placement of the front plate.
    Worth a try.
    If all that fails just go here and plead your case:
    www.speedingfineconsultants.com/
