Adding hp to ironhead sporty n chromin alloy wheels
    Nitrous Oxide, Electronic Ignition and a better Carb is the cheap way to fix. As far as a Chromer in Sydney, you will just have to ring around to find one that will do the job for you. Is it Wire or Alloy Wheels? . if it's Wire I can hook you up with new ones.
    Post a photo of your Bike
  • Choco
    Choco
    Go for the S&S carb first when my mate had his Iron Head Sportie he put a S&S carb on the bike and the difference in power gain was unbelievable so much so that that his clutch started to slip under power it's a good starting point.
    hi, if it hasn't had the cams changed you will never get any good performance out of her , 1979 to 85 have  Q cams they are for the EPA man , a good set of andrews  cams , hi-4 type ign system , carb, etc  then C-RATIO g/box , !st the cams  cheers ,     forget the NOS ?
