Online: GGUser731, baldy1450
BR apes fitted to Rocker
  • Frank7214
    Frank7214
    Fitted my 1 1/2 inch bars and risers (New Wave 2, 12 inch apes) by BR Custom.
    Looks the part
  • Frank7214
    Frank7214
    You now sit in the bike instead of leaning over it. Great feel and ride. A lot more relaxing to ride and just below shoulder height.
  • kanunski
    kanunski
    Looks great mate, really like it, apes look great on there.
  • Frank7214
    Frank7214
    $850.00 for bars and $500 for cables and other odds and ends. About 2 days work fitted by myself.
  • AlfieDelux10
    AlfieDelux10
    Nice bars and ride brother.
  • Frank7214
    Frank7214
    Mate you are looking at about an inch back. But remember you can adjust bars to suit. I chose to have bars line up with front forks and I am very happy with ride. There is a downfall to apes and that is I find that you do lose handling ability. But you do get used it. There is a little bit of flex in the bars but if I changed the tripple tree rubbers to the plastic type, this would eliminate the flex.
  • MIKER
    MIKER
    Great looking Ape's , makes your Rocker look
  • hardcorerevhead
    hardcorerevhead
    Looks F...n great Frank. Not up to changing bars on my rocker yet but yours gives me insperation.
    Keep the hammer down n ya heals up!
  • spend09
    spend09
    I love the look of the apes on the Rocker. I have a 09 rocker and would like to know where you purchased them. I would like the size risers you used  and the height of the apes if possible. parts numbers would be great if that is possible.
    Thanks, Mark
    spend09@gmail.com
  • SoftailSteve
    SoftailSteve
     looks good
  • Wynchester
    Wynchester
    Those look frickin Awesome! Best lookin mini ape I've seen on a rocker. I checked out the guys website and videos.
    Think I'll have to get some myself. What risers did you use to allow the 1 1/2 inch diameter?
  • Frank7214
    Frank7214
    They are 1 1/2 diameter risers as well. Speak to him, he will do anything for you. Good product.
  • Squid83
    Squid83
    I really like them bars mate. I wish Burlieghbars kept there's more straight from side on like these.
    If you don't mind, when did you order these and what did they sting you for shipping? I got BR bars on the train I ordered at the beginning of the year for $120 shipping. Called up a few months ago for another order, they wanted $450 just for shipping the same bars. Nuts
  • Frank7214
    Frank7214
    4 years ago at $850.00 delivered.
  • punkin
    punkin
    I Just got 14" apes on my 09 as well. I've found the handling improved immensley. I no longer feel like the bike is trying to throw me into the ditch going round corners or over bumps (as muchsmiley) .
    I have found the sitting position a bit harsher on the lower back, but the wind pressure is much less on the arms, shoulders and neck wich was one of the aims.
    The difference in confidence in the handling is amazing and unexpected. I no longer have to look like Rossi hanging of the side to get it to turn and the 'input' needed to steer is back in line with a regular motorcycle. A very great improvement on short runs, but i only had it back a couple days and i don't know what it'll be like over a run more than an hour yet.
  • Frank7214
    Frank7214
    Great example of a Rocker. Good work.
  • Frank7214
    Frank7214
  • punkin
    punkin
    Thanks Frank.
    Thanks Frank.
  • Wynchester
    Wynchester
    Hey Frank,
    What length extension did you need on your lines and cables?
    I've got a set of 12" apes with 1" risers I want to put on my rocker.
    I checked on with harley and the only setup they can do me is made for 4" risers.
    I'm thinking I might only need 2" over stock?
