Online: Merv
TTS help needed
  • BURTO
    BURTO
    Ozroder, Is your map...AE176-002-MAT-027... the go for a 2-1 and A/C set up on a 96"?
    If so, I might give it go and WILL let you know the results.
    Thanks, Burto.
  • BURTO
    BURTO
    Well, Belkin F5U409 cable arrived today. WTF!!! She no fit the TTS interface!
    Not without hacksawing off the locking nuts anyway. Same locking nuts as on the interface!
    Will have to do this and then speed tape the fuckers together! Nothin a bit of "Bush Mechanicalness" wont fix!
    Strange no-one on this or other forums have mentioned this, or have I missed something?
    Would'nt be the 1st time!
  • BURTO
    BURTO
     Ah yes, I have missed something!!
    Obviously the Belkin is to convert the serial/serial cable to usb.
    I have the TTS serial to usb cable, which I believe is dodgy.
    Thats OK, as I said, I can bodgy it up to work. Its the same male and female connection, its just the locking components, ie. the thumbscrews and nuts. that hold the connection securely together that is wrong. I've got nuts and nuts instead of thumbscrews and nuts!
    Hopefully this will prove that my original cable is faulty, otherwise its back to the drawing board regarding my loss of data connection.
