Sheep skin seat covers
  • Two tone
    Two tone
    Answer to ULTRA 2010s question. where did the seat covers come from?. www.goodwool.com.au   Good Wool Store 49 Queen St BERRY 2535. Ph0244642081. Check with the dealer if the 2010 seat is the same as the 2009
  • RumDeluxe
    RumDeluxe
    Question without notice on the only thread I could find on the subject.
    Has anyone had contoured sheepskin covers fitted to their rides ?
    If so - how did they compare "comfort wise" in comparison to the original seat.
    I am aware of  Brisbane Manufacturer who makes to order with a 6-8week lead time.
    He needs my seat for about a week to make a template then the cover is made to order.
    They aren't cheep - comparible to a new seat, but supposed to be the ultimate in comfort for the long ride.
    Anyone done this already ?
  • rooshooter
    rooshooter
    had one fitted to my old bike......07 electraglide.... and was reasonably comfy, but not a great fit
     bought from good wool store ...well made but a little too bulky, felt like i was actually sitting on the whole  fukn sheep
      eventually sold to a guy on ebay who was very happy with it
       i think they would be better if the sides were made out of some different material so as to reduce the bulkiness
      and dont forget about practicality in wet weather
      ended up changing ta a sundowner seat which was graet on long trips
     just my opinion
  • RumDeluxe
    RumDeluxe
    Cheers rooshooter - all opinions gratefully accepted.
    Have looked at the Air Hawks as well - they might be a better long distance option (and easily removable).
  • Boy Racer
    Boy Racer
    Just took mine off and found the seat a whole comfier without it. The seat can give a little now whereas before it was just the sheepie. better without methinks.
  • Boy Racer
    Boy Racer
    ""bought from good wool store ...well made but a little too bulky, felt like i was actually sitting on the whole fukn sheep"" Prolly ok if yer a kiwi. :-)
  • Two tone
    Two tone
    Yep they are a bit bulky but they stop ya ass from getting hot.Try cuttin some old sheep skin car seat covers up first.
  • flhrc2008
    flhrc2008
     I've got one to fit 2008 RK, (including rain cover) if anyone's interested. Reason I don't like it is if you forget to cover it  ... it's just easier to wipe a leather seat down
