Replacing rubber handlebar bushes
    I sell a Red Urethane Bush Kit, $15.00 , VPW 03 8405 9212
  • HAMM3Rsix
    HAMM3Rsix
    has anyone had trouble when they fitted solids i would like to do this to a set of drag bars on a fatboy lo
  • braando
    braando
    What you have to do Dick is.........go and buy a brand new set of urethane bushes.........then fit them..........now......go and find that brick wall and wedge the front wheel against it then jerk hard again mate..................oh dear.....too many jd's this end i feel........hic.....!
  • HAMM3Rsix
    HAMM3Rsix
    what is that suppose to acheive i have done the stock ones up with a torque wrench , I will be fitting a set of the urethane bushes but what does the second part do?(ie jerking against a wall .And not that kind for all the deivates out there LOL ) if the are torque up is there still some sloppy or are you just trying to set the new bushes.
