Online: Soapbox2627, softfat
CB Radio
  • Ultra2010
    Ultra2010
    I'm having trouble with the CB on 2010 Ultra. Anyone know which is the CB Antenna and what frequency it works on?
    Dealer doesn't know the answer :-(
  • Sturgis
    Sturgis
     See my reply bin the Workshop thread.
  • MUSIC
    MUSIC
    you haveto set it up atthe headset firstly when it is turned OFF. If you are in MELBOURNE, PM me and I can show you through it. USE Channel 40. It gets you through most things.
  • Ultra2010
    Ultra2010
     Hi Music, I'm in Perth. So if I have the headset all plugged in and CB is off then turn it on?
    I noticed that the radio is connected to the left side antenna (looking from the rear) and that has a screw in connection. The other antenna has a thin wire connection like a car radio antenna. I wonder if it is connected incorrectly at the back of the radio? I would have thought the CB would have the screw type connector like the one in my 4WD..
  • Two tone
    Two tone
    So you like the sheepskins eh. go back and delete the question off show us your ride..Got the skins from over east think they were about $100 cheeper including postagethan over here. I will dig out the recipt and let you know.
  • CHARLIE
    CHARLIE
    CB ON THE RIGHT RADIO ON THE LEFT LOOKING FROM THE REAR.CB IS SHIT ANYWAY I USE UHF MUCH BETTER.CHARLIE
  • bhulands
    bhulands
    Hi
    Does anyone actually use the Electroglide CB? If you are, what is the meet and greet channel?
    In 6 years of owning Ultras, I've only ever spoken to a Wing owner. That's sad.
    Brian
  • aussiesport
    aussiesport
    donty bother with the cb bud put a fuckt up hardcore cd on and crank it :)
