Online: John.R
Lyndall Brakes
  • Pedro-Rollies Speed Shop
    We are proud to announce that Lyndall Brakes are now distributed exclusively by Rollies Speed Shop ( www.rollies.com.au ) in Australia.
    Lyndall Racing Brakes ( www.lyndallracingbrakes.com ) has been a leader in Premium Motorcycle Brake Pads for over 12 years. Born out of a racing heritage, Lyndall found a need for better braking in American V-Twins and brought together the latest technology and their passion for motorcycles. Lyndall brake pads come in two compounds for your individual needs.
    Z+ Compound Brake Pads
    To develop the Z+ compound Lyndall started with a racing brake pad material and worked their way backwards. Lyndall wanted to provide the optimum stopping power that was suitable for everyday general purpose riding. Lyndall's Z+ pads are a DuPont Carbon-Kevlar (organic) compound that will work as well right out of a driveway as it does after a long day of hard riding. This is the most rotor friendly pad in the industry. It produces no dust, no noise, and no rotor wear while providing 20% more stopping torque than the stock pads. The service life generally averages about 30,000Km.
    Gold+ Compound Brake Pads
    The Gold Plus pads are a DuPont Carbon-Kevlar (Organic) compound and is Lyndall's latest advancement in high performance friction materials. This racing formula offers extreme stopping power in both wet and dry conditions. This is as close as a full race pad as you can get without it actually being a race pad. Lyndall softened the compound to make it better for street riding while still providing premium stopping power. The Gold Plus pads are ideal for heavy touring and hard stopping. It produces no dust, no noise, and no rotor wear while providing 30% more stopping torque than the stock pads. The service life generally averages about 30,000Km.
    Not all brake pads are created equal
    Some technical information can help you understand the differences between the kinds available on the market. There are three types of friction material commonly used for motorcycle brakes: sintered metal, ceramic, and Carbon-Kevlar.
    Sintered-metallic brake pads, which have a high metal content, are typically hard and abrasive to the rotor surface while offering moderate stopping power and mechanical strength. Service life tends to be significantly lower while they also tend to run more dirty and noisy than other types of friction material. They are inexpensive to manufacture and are the cheapest pads on the market.
    Ceramic brake pads usually have a high copper content and are sintered as well. While ceramic pads generally offer a slightly longer service life and run cleaner than sintered-metallic pads, they offer only moderate stopping power.
    Carbon-Kevlar pads, often referred to as organic pads, usually have a small percentage of iron or nonferrous metal and are softer than other friction materials. Carbon-Kevlar pads typically run clean and quiet, and offer good stopping power. They have an extremely long service life and are not abrasive to the rotor because they generate less heat than other friction materials
    What makes Lyndall so special?
    LYNDALL pads are of the Carbon-Kevlar variety. They contain a premium blend of DuPont Carbon-Kevlar, nonferrous metal with a high transfer rate. Once the pad material has transferred a layer to the rotor, the rotor becomes one big brake pad, stopping against the two smaller brake pads positioned in the caliper. The result: incredible STOPPING POWER, NO DUST, NO NOISE, NO DRAG, NO MEASUREABLE ROTOR WEAR, and the HIGHEST SERVICE LIFE of any pad on the market.
    Which pad should I use on my motorcycle?
    If you are running stock tires, stock chassis and your bike is set up for stock horsepower then you should use the Z Plus pads, as they will provide as much stopping torque as the stock tires and suspension can effectively manage. The Z Plus pads will provide a noticeable upgrade to the stopping power over the stock pads.
    If you are running aftermarket tires, high performance engine, have tuned your chassis (i.e. Gold emulator valves, upgrade shocks, etc.), or ride with a lot of gear or passengers on your bike, we recommend the Gold Plus compound as it is better designed to provide the most stopping power under any riding conditions.
    Lyndall Racing Brakes offer pads for the following:
    Harley-Davidson® Victory® Iron Horse® Buell® Jaybrake® Indian Motorcycles® Big Dog Motorcycles® Brembo® HHI® Performance Machine®
