Online: Retroman
dyna brakes upgrade
  • wilso
    wilso
    Hi all ,  just wondering if anyone out there has upgraded the brakes on their older dyna?
    im looking at upgrading to the newer 2000 model and up brakes for my 99 wide glide , should fit ay?
    cheers , wilso
  • Dyna1994
    Dyna1994
    yes , i have a 94 dyna with the twin discs , i upgraded to from the standard to twin pot gma brakes front and rear , stops like a treat
  • Spanna
    Spanna
    Mines in the shop at the moment getting Hawg Halters four piston rear brake refit. http://www.hawghalters.com/
  • wilso
    wilso
    whats the upgrade worth spanna if u dont mind me askin?....
    cheers ,
    wilso
  • Spanna
    Spanna
     1100 installed mate.
  • jon doe
    jon doe
    twin disk it
