Online: Soapbox2627
Assembly Lube
  • 2005 FLSTFI
    2005 FLSTFI
    Went to my local dealer the other day to buy some Assembly Lube & they don't sell it. Said to guy " what do the fellas out the back use when they install cams" his response was " they soak cams & camplate in oil for about 1/2 hour".
    Anybody do this with their cam swaps or should I ignore his statement & use assembly lube. This is my first cam swap & don't want to shortcut it.
    Could I use another brand of Assembly Lube other than SE.
    Cheers for any replys
    Mal
  • 2005 FLSTFI
    2005 FLSTFI
    Thanks for your replies Scotty & Oz.
    Just bought some Redline Assembly Lube, figured being Redline it must be good shit, expensive though.
    Mal
