Online: FONTANA302
HOTTOPPERS
  • rider
    rider
    These look interesting.
     "Hot Toppers® are USA made chrome bolt covers that friction fit over American standard fasteners.  Hot Toppers® can be placed on as many as 250 spots on your motorcycle. "
    www.hottoppers.com/home.asp
    Edit Note:      Found Zodiac caps through Cassons,,, look a much better deal.  cassons.com.au/IN_Listing.asp
  • AJ56
    AJ56
    I put the engine kit on. yeah they look nice. but wait till you have to get them off to do some work on things... bit of skill involved so as not to damage the covers
  • SuperGlide
    SuperGlide
    yeah they can be a PAIN.
    you can get very good value prices at M&M / zanottis etc
  • rider
    rider
    Yep and they are a bit on the pricey side when you compare them to Zodiac chrome caps and plugs.
    I bought a few of the Zodiac ten packs in different sizes to try them, not too bad
    I'm going to try a kit from Zodiac for the WG priced at around the $70.00 mark. Sounds a lot cheaper than the Hottoppers.
    Distributed by Cassons, so order them from your local bike shop.
