Online: Stuart
MIDS VS FORWARDS
  • LOW06
    LOW06
    Gday forumers, just wanted some info on how handling might be affected if i changed my mids to forward controls, and what about getting my leg around the aircleaner?which is better aftermarket or genuine? who sells aftermarket here?
  • kingchops
    kingchops
    Handling is easier with mid controls, although I had forward controls on my Sporty and I found them ok.  After market are cheaper but generally not as good quality as genuine, I had aftermarket controls on mine, they worked and looked good, but I did notice the chrome starting to wear off the pegs after a year or so.
    One thing I found was that after putting forward controls on I needed to shift the bars back to make the bike comfortable to ride.  I ended up with 4.5" pullback risers on the bars.  A bit more would have been good but I found 4.5" was the most that I could pull the wiring back without modifying it.
