Online: speedzter
true Duals anyone???
  • Poddy
    Poddy
    G'Day all,
    couple of questions on Trual Duals; I trust someone has fitted them
    OK,
    1. Do you need to change out the shifter linkage as it appears that it will hit the l/h pipe as it comes out?
    2. If I am only changing the pipes do you need a remap of the ECU or do you need to invest in a PC3 or whatever
    3. Anyone done it at home (pipes that is ), how long did it take, do you need any special tools etc (and NO I ma NOT a special tool, just a standard tool )
    4. Which make did you go for and did you buy off the net or local (big price differenct)
    5. Do you have any photos of your pipe  (of the exhuast pipe not ya bong)
    Poddy
