Online: beaglebasher
my local aldi
  • ubdead66
    ubdead66
    hey all at my local ALDI they have motor cycle GPS's reduced to $100 from $200. I think they are uniden. Im going to get 1 Friday i hope . If anyone else would like 1 let me know the only catch is im strapped for cash so if i get you 1 you will have to come over on sat to pick it up with the cash . And if your going to do that you might aswell go there and get one your self  its Durack Aldi on Blunder rd. They have been there for a long time 2 weeks ago they were $150 this week $100.
    happy to pick 1 up for whoever tho .
  • Hipshooter
    Hipshooter
    Wait another month and get on for $50
  • beagle
    beagle
    Folks, remember the fittings are for 3/4 inch bars. I still have to figure a way to install it with a one inch clamp. Had it on a spare japper I had at the time. Best to wire it through the ignition, or headlamp wire, as it will stay on all the time, unless you actually turn it off and not leave it on standby mode. Learned the hard way with a flat battery after a week away. They aren't a bad toy, but you do only get what you pay for with detail and features. A top range bike GPS will set you back anywhere from several hundred to a grand.
  • fundi
    fundi
    hi guys
    yes there at durrack for $100.00
    pick one up yesterday and fitted it
    yes you get what you pay for but it works
    thanks for the tip
    fundi
  • Kustomtown
    Kustomtown
    I don't know how you got them so fast onto your bars fundi? A SLR digital camera has overtaken my priorties now, so the GPS will just have to wait....thanks for offering to help out Ube....
  • Kustomtown
    Kustomtown
  • Kustomtown
    Kustomtown
    Uh, uh, uh…haw, haw, haw.
  • Kustomtown
    Kustomtown
    Ah, it'll never get old...
  • beagle
    beagle
    Hey Fundi,
    How / where did you fit it on the bars.
  • ubdead66
    ubdead66
    lol waiting for andrew and im getting westerns so will be waiting for them . The Gps is fine does the trick water proof and blue toothed its a goer IMO
  • monarofan
    monarofan
        <   yep,="" looks="" about="" right  ="">
  • ubdead66
    ubdead66
    so there is the P clamp held together with bolt from GPS
    all together
    finshed product
    Wire goes behind the speedo  under tank bib under seat straight to battery .Just cant leave turned on and asif i would cause i wouldnt  leave on bike for some to steal.
