Online: wildchild
Dyna owners unite.
1/5
  • kensim
    kensim
    18 years ago
    yea stix am interested in hearing your thoughts on the fat cat,am thinking about getting one ,where did u get it from ,how much if u dont mind?
  • nobody
    nobody
    18 years ago
    Hey Stix
    Don't you mean how much can be gotten from a 107 without head work?
    Just joshin
    Keep the info coming as I am intrigued.And hope you have better luck with the Daytona Twin Tech stuff than some of the other people I know have had.When they work they are fantastic,but a lot of "WHENS" unfortunately
    nobody
  • kensim
    kensim
    18 years ago
    yea that is agood price stix,the cheapest i found is 527 plus 175 postage thats USdollars,
  • BACAMICK
    BACAMICK
    18 years ago
    shame about the 107 but im sure they will sort it 4 ya ,
    real nice seat there mate  do you find it comfy ? mines real comfy  will post some pics 1 day
    love the DD , must get 1 i recon
    i dont have a 6th gear indercater with the thunder max
    also lost my brake light when it rains ????????????
  • BACAMICK
    BACAMICK
    18 years ago
    beats having all the holes
  • syco_bob
    syco_bob
    18 years ago
    where did you get your black shox from Stix? Is it a lowering kit? Are they that firm that you dont need springs? I'm wanting to lower my rear and looking around at the different options. Picked up my 06 Bob on the weekend. First HD and all so I'm asking alot of noob questions. The stargate thing looks ok if you really hate the holes. Looks a bit metric though in my opinion. My bob is matt black, I probably wouldn't care about the holes on mine.
  • syco_bob
    syco_bob
    18 years ago
    kool thanks stix.
  • syco_bob
    syco_bob
    18 years ago
    I got those Ness mirrors too, they're bloody tuff huh!
  • cattleprod
    cattleprod
    18 years ago
    Thats a great lookin bike stix.
  • bullet
    bullet
    18 years ago
    look'n forward to hearing how they go i need to upgrade my stockers they constantly bottom out 2 up
    18 years ago
    Stix... the note suggests fitting 11" units may require the reshaping of the rear guard to avoid damage from and of the brake caliper... did you have any issues?
  • syco_bob
    syco_bob
    18 years ago
    I have the same problem with the staples. The dealer offered to install the add on HD pillion seat(which is really revolting anyway) and a week later when I removed it I noticed my guard had 8 staple marks on it. I was fuming. I went back to him and got a $360 2 up seat out of it and called it square. Still not happy but I'm happy with the new 2 up and u cant see the scratches when its on.
  • bullet
    bullet
    18 years ago
    wondering if someone  can help me, yesterday while riding my speedo and odometer went dead! check engine light came on too, when i slowed down to under 70k it came good again go up over 80k and it blanks out again also while blanked out if i used either brake the odometer flashed on for a second, now today as soon as it comes over idle it blanks out and check engine light comes on and indicators dont auto cancel, I checked the codes and it either comes up with a code 11 which is a battery voltage high or no code at all any help would be appretiated its a 2001 low rider carbied 88ci
  • bullet
    bullet
    18 years ago
    yeah im on my way but was hoping some one would say something like its a speed sensor very common but some time you just have to pay the man
  • bullet
    bullet
    18 years ago
    thanks road train i checked the charge rate and its 13.9 at idle and goes up to around 18v under revs as soon as it hits about 15v it blanks out so im assuming its the regulator the battery checks out ok
  • syco_bob
    syco_bob
    18 years ago
    I lent my bike to the old man yesterday and he gave it back last night. The fuckwit twisted the fuel guage, totally smashing the guage to bits. You would think (even after your told that its not the filler cap) that you wouldn't force it if it didn't move or at least call and say which one is the fuel cap. What an idiot. So guess who's looking through the custom chrome catalogue looking for the tastiest most expensive fuel gauge? I'm not payin....
  • syco_bob
    syco_bob
    18 years ago
    i've decided to go with the HD flush mount gas cap and fuel guage set. Has anyone got these? Easy enough to fit?
    18 years ago
    I did my bit stix
  • bullet
    bullet
    18 years ago
    after buying my 01 lowrider ive found it doesnt handle contry roads 2 up did a 400k ride and cased out all day my sump isnt looking to healthy now!! does anyone have any sugestions ill raise it if i have to  and where do i find bike of the month?
  • vladt
    vladt
    18 years ago
    Hey Stix, Just a quick question in relation to your bike mate.
    Which license plate holder, mirrors and derby cover do you use?
    While it may sounds that "I want to be like Stix" my SB isn't quite there yet...
    Vlad
1/5
