Online: B0nes, Merv
Map choice
  • Zabs103
    Zabs103
     hi
    just did a 103 in my bike, 2006 dyna      with o2 sensors now
    am using tts
    i have 255 cams with a -4 andrews gear, 30 thou cometic gaskets, flat top hd pistons, 50 mm se throttlebody
    heads cleaned up a bit with 1.9 and 1630 in and ex valves
    there does not seem to be a good map match
    does anyone have any suggestions where i should start
    so far i have loaded a ms 176-002, and changed the injected rate to 4.89
    would appreciate any help, as this is all new to me (bet you have not heard that before)
    thanks in advance
    Zabs
  • Zabs103
    Zabs103
    Thanks guys for the advise,Will take it on board.............Have found a TTS dealer with a dyno & most probably take it down after a few Ks of running in. I'll keep you informed of my progress.
    Cheers Zabs103
