Online: John.R
FXR Exhaust
  • Nifty!
    Nifty!
    Has anyone had anything to do with the Thunderheader pipes out of the US. There is a second hand set on ebay but wondering if there is am Australian distributer as I cannot track one down. Not sure if this exhaust is any good and looking for anyones experience....
  • Rowdy
    Rowdy
    If its a 2 into 1 from what Ive heard they make good power and torque ,they look a bit ugley but thats my opinon,there loud,Check out there web site and on you tube,M&M Cycles in the US deal with them good company to get parts through just had a D&D Lowcat sent from them no dramas.I run D&D 2 into 1s on both my bikes and think there a great pipe might be worth checking them out as well if your looking at 2 into 1s.
  • Nifty!
    Nifty!
    Thanks Rowdy,
                                      Yeah, 2 into 1, as I have gotten past the look of them now and got used to them. I hear plenty that they work a treat and finding it hard to find a bolt on set for my model.
    Cheers for the options and will have a look at the D&D, had a look at Thunderheader web site and will have a look at u tube as well. See a set on ebay but think they might be a bit knocked around....
    Cheers.
  • Rowdy
    Rowdy
    Nifty where are you located as if your from around this area might be able to go for a ride if you want to check out a D&D fitted up to a bike ,there a nice fitting system and look good as well .Ive ended up with 90hp and over 102ftlbs of torque with only minor mods .
  • Nifty!
    Nifty!
    Might take ya up on that offer Rowdy, I am just up the road from you , at the Redlands. I will try and work out a day in the next few weeks, and PM ya....
    Cheers for the offer,
    Nifty....
  • Rowdy
    Rowdy
    No dramas Nifty my Dynas in pieces at the moment but my Fatboy low is a runner and if you want to check out the Dyna I can meet you somewhere and go for a cruise to my joint to have a look,both have D&D pipes fitted,Dyna runs but just unable to ride it at the moment.
  • watto
    watto
    Hi there Nifty,
    had a ceramic coated black thunderheader on my FXDX for a few years and it was a great system. Loud when you were under the hammer, but a good deep throaty loud, not a bark.
    Good for around town though as quite reasonable when just cruisin along.
    Got mine through Geelong HD. They sourced them from US J&P cycles from memory.
    Watto
  • Nifty!
    Nifty!
    Good stuff Watto,
                                    Cheers for the info, I know the system is a bit on the fugly side, but I hear they work well and have a good sound without that ear piercing shitty bark like some systems. I might contact Geelong HD for a quote....
    Cheers,
    Nifty....
