Online: Kato
Blending question
  • streetdjack
    streetdjack
    Hi guys
    In process of blendig my vE maps after some vtune sessions, I need some advice
    here are my last vtune :
    [url=http://www.servimg.com/image_preview.php?i=495&u=12417567][/url]
    As you can see, I've made red marks around the blocks where 80kpa has been reached...
    my questions are :
    - can i blend those values directly even if they come from yellow cells : for ex Front VE 1750@25 = 103 -> all the following cells to the right ?
    - if there are two values on the same line, one white and one yellow, which should I choose ?
    for ex : Front VE 2500@30 = 90.5 in white versus 2500@40 = 91.5 in yellow -> should I use 90.5  or 91.5 to the right ?
    - what about the "downblending" ? : should I stay with the values from the original map or should I blend the values I've reached even
    if they are in yelllow cells or use only the white ones ?
    my opinion would be to always use the higher value reached to stay on the rich side, but it's only my opinion...
