baked on beer
  • matt08
    matt08
    while away at eden on the weekend a stubbie leaked out my bag and is baked onto my pipes ......
    any tips cause the crap wont come off ?
  • Sledge
    Sledge
    Try a Balbo Power Pad for cleaning your pipes,
    I have used them to get the melted rubber from my boots off no probs
    and as the packaging says
    "cleans the impossible!"
    you can get from big W or the hardware shop or the like.
    Cheers Sledge
    Ps and nearly no elbow grease
  • matt08
    matt08
    nah i dont drink and ride .... only my good buddy spartan knows how it got there .........
    thanks for the tips fellas
  • rider
    rider
    Sounds like a job for More Beer
    Pretty sure the beer didn't do anything - it was his tongue melting onto the hot pipes that left the mark.
  • Lastrain
    Lastrain
    Autosol metal polish and a bit of rubbing .... great shit works on chrome, aluminium, staniless, brass, copper, glass ... haven't found a metal yet that it doesn't work on.
    Sounds a lot like Blue-Job, Autosol will take off blueing, I used it the other day to remove the wifes melted boot remains, works really good on aluminium, I can get the mirror finish back on the clutch and brake leavers with it
    Most auto shops have it, comes in a gold/black tube like tooth paste
  • Sledge
    Sledge
    I recently got put onto a product called
    Liquid Reflections.
    Works just as good as autosol if not even better and a whole lot faster.
    I got mine from the OG speedshop in Adelaide.
    about $21.00.
    and goes a fair way as well
    Cheers Sledge
  • clarkie
    clarkie
    try getting pipes hot with engine running and try pouring boiling water over damaged area,rub with soft cloth will doing so,use old garden glove to protect hands,only my 2 cents worth.
