Headlight is garbage
  • Ollie
    Ollie
    I have a 2008 fxstc.The headlight beam is just a "square" of light on the road.Cant see bugger all.Anyone else had this prob?Is it just a matter of going up in wattage or something else?Would appreciate any advice.
  • Bobtail
    Bobtail
    Might be just a simple case of adjusting the thing up a bit......and maybe Ando needs to loose a bit of weight......
    Bt
  • odinsvolk
    odinsvolk
    Take your sunnies off...
  • Buelligan
    Buelligan
    Help this guy out !!!
    Hes a mate of mine, and relys on me and my Dlux to light his way!!!     Really his headlight beam is dismal , any SERIOUS suggestions on improving it!!
  • Ollie
    Ollie
    G`day Hilly.
    Thanks for the input.I`ll look into it.
    Onya
    Ollie
