Online: obisteve
Show us your bike - Touring
9/42
    Great photo. nice and sparkly. Nice ride too.
  • killerchef
    killerchef
    very nice 99rk. what bars are they mate ?
  • scotti
    scotti
    Yep fuckin shmick ride man !
  • 99Roadking
    99Roadking
    The bars are Bulls Horns but they're 2 years old now so I can remember the details. Inch and a half and hidden wiring type!
  • 99Roadking
    99Roadking
    Few new additions.... Hard Bags and more chrome rails!
    What rims are they and cost?
  • 99Roadking
    99Roadking
    Front wheel is a King 48 Fat Spoke 21 x 2.15 fitted with Metzler Marathon Whitewall MH90-21 from Walka @ VPW (forum sponsor).
    Check out the VPW website for the most current price and then give Walka a call for forum member discount.
    Matching Disc Brake Rotors also available.
    Best money that I've spent - never had as many positive comments on how it changed the bike.
    dont see it on their site?
  • 99Roadking
    99Roadking
    OK... I looked it up for you.... the wheel is $407 and the tyre $261.
    If you don't need whitewall, then it's almost $100 cheaper for that tyre.
    Ta , did your std discs bolt up to it
  • 99Roadking
    99Roadking
    Yeah standard front discs do fit.
    What size wheel axle do you have? They changed from 3/4 to 1 inch in 2000.... mine is the 3/4 axle.
    You may have to shorten (or make some new ones) the axle spacers because the new wheel has bearings flush to the wheel whereas the standard RK are inset. Not a hard job to do it all though.
    You have got me there..... its a 2012 street glide so guess its the bigger one. Will have to measure it.
  • scotti
    scotti
    99Roadking , did you notice any change in handling with that rim tyre combo over the stock setup ?
    The guard remains at stock height right ?
    Rails and hardbags do look trick , but that front rim just sets it all of man , Cheers
  • 99Roadking
    99Roadking
     The steering is a bit lighter and makes the bike easier to handle in traffic. Didn't remove rhe guard but had to modify the front bumper mounting bracket to clear the extra 20mm overall diameter increase in size. I used to love the leather bags but now the hard bags are my favourite.
    What pipe is that?
  • Burnzi
    Burnzi
    85 FLHT. Mt Wills, High country back road touring
  • glenpick
    glenpick
    My ride - cruising around Daylesford
  • Chaser
    Chaser
     Beautiful!
  • scotti
    scotti
    Yeah nice pics fella`s , great rides and countryside also !
  • KDZS
    KDZS
    I went with the Willy G Skull motif and as usual (and to the wife's disgust) there is a long way to go yet.
9/42
