Online: Hilly, softfat
V&H big radius for 09 fatboy
  • QLD Fat
    QLD Fat
    I have a 09 fatboy with pillion footboards for the missus. Can anyone tell me if V&H big radius 2 into 2 will fit with the pillion footboards fitted? Also anyfeedback on there sound? Thanks
  • watto883
    watto883
    dont know about the fit BUT the sound to me is the BEST there is . have 2 mates with them on 08 softail standards
  • FatboyMick
    FatboyMick
    Hey man, I'm wanting to put the rear boards on mine as well, i reckon they'll fit,this is my '07 with V&H big radius
    Almostfinished.jpg picture by FatboyMick
  • FatboyMick
    FatboyMick
    Forgot to mention the sound, i personally love the sound, i had S&S slip ons on it from new, it had a real low rumble note, i liked that. But i put the V&H on it this year, now more of a crack than a rumble if that makes sence. I changd the pipes 'cause it was a pain in the arse to get the axle out to change tyres, having to remove the slip ons everytime. i was told to turn the axle around, but i wasn't game enough to do that. I don't regret it, riders behind me think they are  loud, but  from where i sit, they sound shweeeeet. That's just my opinion of cause.
  • QLD Fat
    QLD Fat
    Thanks Fatboy Mick, The V&H 2:1 look great on your bike. Still like to know if there gunna fit before I fork out for the pipes because the rear boards will have to stay
  • Taffymarsden
    Taffymarsden
     My CVO Fat Boy came with Wide Radius courtesy of the previous owner. So loud I was sure I get done for noise so I took them back to the dealer and had the original SE2 pipes refitted. Much nicer sound, very deep, BUT LOUD!!!! Worse than the V&H although the tone is better. I'd have gone back the the V&H because I love the look, but the bike performs a zillion times better with the extra back pressure from the SE2s and just a bit of decel popping - the V&H backfired loud enough to have pedestrians hitting the deck. (Long winded way of saying the V&H looked a million bucks but had a neg impact on performance).
  • m0ngre1
    m0ngre1
    QLD Fat, 2 into 2 should be fine but if you go 2 into 1 big radius you need a lift kit for the rear pegs that you can get from V & H
