Sportster gear box - need advice
  • Pritch
    Pritch
    I have a 93 1200 Sportster with a troublesome 5-speed gearbox.  I have been told you can buy a completely assembled replacement gearbox cartridge.  Does anyone know if this is correct and if so  who is the distributor?
  • DynaRider
    DynaRider
    As in, jumps out of 3rd??????
    Define troublesome.
    They are an incredibly simple transmission, but with just a couple of weaknesses.
    Baker do a complete 6 speed
    Quite expensive I have heard
  • DynaRider
    DynaRider
    I was merely suggesting a common fault
    And welcome to the forums btw.
  • Pritch
    Pritch
    Thanks for all the comments. I took the box out and after a few phone call found someone who really knows what they are doing with them. He pulled it apart and rebuilt it on Thursday afternoon. Just got to put it back in the bike this weekend. Haven't had a ride for four weeks so i'm getting pretty desperate.
    Cheers all..!
