Online: fatbat, Hilly
tts first run
  • harleynt
    harleynt
    Hi
    I did my first Vtune run today. This was a sert that was upgraded by tss
    tuning run
    start in 1st gear  from 20km hold each 5 sec 5klm increase to 80klm
    second gear  from 20klm hold each 10 sec 5klm increase to 110klm
    ride in other gears at various speeds hold for 5 secs
    2nd run hit count attached as bike idles at about 1100 no accurate measurements below that
    have i gathered enough hits in order to have some useable data
    i tried smooth ride and hold for at least 5secs each 5klm increase in 1st and second gear
    i have put original map back into bike asi have not yet started to merge any cells
    2nd tuning run recording historgram 2ndrun20032010.gif http://www.box.net/shared/raa8gnfoc2
    2nd tuning run  E176-002-B1-1st-003.MT7   http://www.box.net/shared/o37qtqatzj
    2nd tuning run 2nd vtune 21032010.xls http://www.box.net/shared/pq54eooen1
    any advice would be appreciated
    Harleynt - novice in Tuning
  • harleynt
    harleynt
    Hi Scotty
    thank you for your quick reply
    I did create a new map(1) from the first run
    and used that in the second run
    as we had a storm i was unable to do a third run using the newly created second map
    the attached files were from the second run which used the newly created map(2) from the second run
    am i supposed to use the original map withe the vtune from the second run
    i used the newly created map(1) to create the new map(2) with the vtune data files from run 2 run but havent as yet done the thrid run
    What can i do to get more hits in the yellow areas or do i really need them
    and will i get lesser pink cells after my third run
    when i decide to blend cells (after the third run) where do i start as the yellow cells have had some corrections done
  • harleynt
    harleynt
    Scotty thanks for that
    will do a 3rd run next weekend
    and post the relevant maps then
  • harleynt
    harleynt
    Do I need to do anything about how hot it runs
    esp at idle
  • Pine Tree
    Pine Tree
    I'm just curious...how did the cells in the "0" throttle range get so much data that high in the RPM range?
  • harleynt
    harleynt
    Hi
    I did my 3rd run today
    i also created a blended file in excel
    i blended cells that were either white or light pink
    both files are linked below
    I would appreciate any comments before i change the mt7 file and upload it to my bike
    Thank you to all for all the help given to me so far
    Harleynt
    vtunedata-003-230310.dm3 http://www.box.net/shared/4o3q7ggt5v
    ae176-002-b1-1st-004.mt7 http://www.box.net/shared/srj7r9vesj
    3nd vtune 230309.xls http://www.box.net/shared/tumqe0k76t
    3nd vtune 230309 blended.xls http://www.box.net/shared/11uocp3p0e
  • harleynt
    harleynt
    Hi Scotty
    Here is the link to the requested files
    1st file vtunedata-001-210310.dm3 http://www.box.net/shared/kqfhbozg6a
    2nd file vtunedata-002-210309.dm3 http://www.box.net/shared/dr5r2hz753
    3rd file vtunedata-003-210310.dm3 http://www.box.net/shared/4o3q7ggt5v
  • harleynt
    harleynt
    Here is my 2nd tuning run
    1ST map MT7 http://www.box.net/shared/fgp3m2uc55
    2nd map MT7 http://www.box.net/shared/fxpa6kygij
    3rd map MT7 http://www.box.net/shared/mxap0aqm3l
    1st Histogram http://www.box.net/shared/y1z3fap7qo
    2nd Histogram http://www.box.net/shared/8hu9su08jb
    3rd Histogram http://www.box.net/shared/rhm0287j7m
    1st vtune http://www.box.net/shared/5181gb2sfq
    2nd vtune http://www.box.net/shared/55ru4ojlis
    3rd vtune http://www.box.net/shared/pbeq42lf1i
    1st dm3 file http://www.box.net/shared/7q7pl2nq6h
    2nd dm3 file http://www.box.net/shared/mem4hvac4d
    3rd dm3 file http://www.box.net/shared/m69kflc174
    1st vtune excel http://www.box.net/shared/hdr3vaf2qz
    2nd vtune excel http://www.box.net/shared/1kga8q0seb
    3rd vtune excel http://www.box.net/shared/cpjnocc3ii
    Scotty i couldnt work out how you blended the file from my first tune
    I did load it and am still running it
    The bike runs much smoother and very little pinging
    I didnt try out a long run as i wanted to do a second tune
    Hope you can advise me further
    Harleynt
  • harleynt
    harleynt
    Here is the final blended file for my 2007 Fatboy
    AE176-002-B1-final-blended.MT7 http://www.box.net/shared/uzo1l7csam
    I will do one more tuning run using this file to compare
  • harleynt
    harleynt
    Hi
    I have now done a 3rd tuning run
    I have not blended the final fine yet as i need to understand a little more
    Here is the 3rd run 2nd vtune http://www.box.net/shared/pbeq42lf1i
    here is the 3rd run 3rd vtune http://www.box.net/shared/gvku09r8rj
    I dont enderstand why they differ so much
    I tried to do each run in a similar style
    each run was on the same route
    which is the better map to use
    When blending do I ignore the yellow cells and only use the white or light pink ones
    Here is the finalMT7 file that needs to be blended with the final vtune http://www.box.net/shared/jqu6pbez07
    Any advice would be appreciated
