Brake Fluid
  • Sparra
    Sparra
    I did a search and have been reading for an hour but still can't find my answer..For my 1995 Softail the recommended brake fluid is Dot 5....Is it ok to flush everything out and use Dot 4????
    thanks...Sparra
  • Sparra
    Sparra
    Cheers mate...Dot 5 it is then...All I have to do is find some down here as I am 2 hrs from the nearest HD dealer...
    Cheers...Sparra
  • wideglide96
    wideglide96
    yep good luck mate not many plases stock it and dont let some wanker in an auto parts store try to sell you dot 5.1 which is for late model fords cause its different . i had to get some sent down from adelaide
