Bike Lift on Sale at REPCO
1/3
  • kingchops
    kingchops
    These lifts are good but just be careful if you've got a late model Dyna they don't fit (as I found out!).
  • Hound_Dog
    Hound_Dog
    Cheers mate, Im off to get mine now!!
  • ireland
    ireland
    sale starts 18 march
  • Hound_Dog
    Hound_Dog
    Anyone with a lowered bike better make sure of clearance also. Lift range is 115mm thru 418mm
  • FAT TONY
    FAT TONY
    fark I'm blind ! ..................can someone please tell me what page its on - thanks
    does OPSM have a sale on as well !
  • rider
    rider
     @ FT,,, tis in the hi diddle diddle of page 13
  • Oldman
    Oldman
    If anybody is interested, the lift works bloody good and I"ve lowered my Dyna.
    I also use the lift adapter kit from HD (rubber blocks), and with a bit of a wobble to get her seated right, up she goes!!!
  • clarkie
    clarkie
    ill be there at opening time for mine,need it soon.
  • Finny
    Finny
    Got 1 of these a while ago for $150, And its Awesome, I mainely use it for cleaning
  • Hidiho
    Hidiho
    I went to Repco this morning just after they opened, $149 for the lift (normally $277) and Repco even dropped it off at where I'm working, free of charge...
    Thanks for the heads up Beef, much appreciated...
    hidiho
  • Hound_Dog
    Hound_Dog
    Just did some measurements mine is to low...105mm and the minimum on this lift is 115mm. I know there is another brand, I think sold at MCA that is 85MM minimum about $240 from memory. I might just hit them up with the old Repco's doing them for XXX routine.
  • WAGlide
    WAGlide
    Got Mine just then ($149 thankyou discount gods).
    For those who are interested I also ordered  the Dyna Service lift adaptor kit from the local Harley shop. The cost was $38.00 so now I don't have to worry about distances between the lift arms. Part number is  98965-99
  • grpawalky
    grpawalky
     Would one of these fit/lift an 08 Fatboy? Also, for the guys who have them, is there only one height when its lifted or can you for example just lift it enough to get the wheels off the ground, without lifting it 18" in the air?
    Cheers n beers
    Matt
  • grpawalky
    grpawalky
     Come on Tony, its on page 13 mate
    Cheers n beers
    Matt
  • grpawalky
    grpawalky
     Cool, I might check them out tomorrow then.
  • grpawalky
    grpawalky
     Got mine last Sunday, pretty good jigger for the price eh? I like the way you dont need to have it up really high, you can just have the wheels just off the ground for rotation etc.
  • Hound_Dog
    Hound_Dog
    Got mine today, just fitted under mine. Few pumps is all it takes to get it off the ground....bloody bewdy. Easy to wash those white walls now!!
  • V2Evo96
    V2Evo96
    Got mine on Satuday-- much better quality than the POS other one I have.
    I like the safety latch system-- very secure compared to the other POS , and as others mentioned just a few pumps to get the wheels off the ground.
    Most excellent unit!
1/3
