Need Help
  • Finny
    Finny
    If some one can assist or guid me in the right direction it would be appreciated.......
    On my way to work this morning I was gearing down for a set of lights, from 5th down to 4th to 3rd , lights had changed still in 3rd go to take off and the bike had died, Had power ,bike was granking , batt full 1/2 a tank of fuel but , But would'nt turn over. Not sure if its the computer or the coil, Can hear the fuel pump working , Its got me Fucked.........
    Almost forgot 2005 electra glide, injected
    Finny
  • Finny
    Finny
    Thnx HB,
    Scotty would of i done anything to the computer by trying to down load the tts map.......Just a Question, And thnx again
  • Finny
    Finny
    Ok thanks
  • Finny
    Finny
    im hearing ya..........
    So if i have fuel and then spark ,
    But if she no go Marshmello's at my place
  • pricey13
    pricey13
    Finny...i had the same problem on a 2002 ultra fuel inject. my fuel guage shows 1/4 full but then ran outa fuel, bloody thing was empty...took a lot of cranking to get it going. after refueling   when i got home i drained the tank and found about a table spoon of water on the bottom of the tank            one of the two caused the problem     cheers pricey.
  • Finny
    Finny
    Thnx pricey ill have a look .
    Ok i have spark , My air filter isnt the best but ive had worst. I have checked the fuses, fuel pump ok ecm ok . I have played with some wires and checked 4 loose one , Cant find anything............Now time to drain the fuel  after that fuck nose , its off to the shop..
    Cheers Finny
  • Finny
    Finny
    Well after so many fucking hours, Yep as wozza said the hose in the fuel tank that is conected to the fuel pump had come away, A Little thing like that
    Well i would like to thank everyone that assisted me with my problem  And to the dip shit that put my bike back together after the air brushing , FUCK U.
    Dumb ass forgot to put the clamp back on.
    Oh well its running and washed ready 4 a ride tomorrow
    Cheers 2 Rt ,wozza, scotty,  hogbag07 & walka
