Online: Hilly, speedzter
V&H DOUBLE BARREL PIPES
  • RAGLE
    RAGLE
    Has anybody seen or heard these new and cheaper pipes? I see they have a smaller header section, but still maintain a full heat shield, and the power chamber. And probably don't have a billet end. So are they just a cheaper version, or will they have slightly less performance value, with the small header section?
  • Purnong
    Purnong
    Just gat a set of these today and they are slightly larger than the stock Harley pipes
    And by slightly larger I mean points of MM
    Will be fitting them in the next few days and let you know how they go
  • Purnong
    Purnong
    Yep, Robs cycle supply is better on the shipping for sure
    Now, about these pipes
    I bought the double barrel Q-Series and after worrying they would too quiet I'm glad to say they're not
    In fact if these are the quiet ones I'd hate to hear the loud ones They have a nice sound to em down low and if you give it a handfull of throttle they bark as well
    At highway speeds cruising they mellow right out to the point the exhaust note is still there but you can hear everything else as well
    I like em, The bike still sounds like a Harley should when you want it to but they don't give you the shits on a long run
    All in all very happy with the pipes
