Online: binnsy, HD17, Hilly
hidding wires in your handle bars
  • Sharpy62
    Sharpy62
    Morning All,
    I have purchased a great set of Burleigh bars (2' roller bars) and you can run the wiring through the bars, which would clean up the look of my 2005 Softail.
    Has anyone done this before?
    Do I have to cut wires or is there a spot where the connectors will come apart?
    Sharpy62
  • Sparra
    Sparra
    Have a read of this...
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=4&tpage=1&view=topic&postid=11910#11910
  • robert65
    robert65
    yeah mate there are connectors under the tank, you have to take out the pins from the plugs just match it all up when you put them back in. i put the same bars on my 08 softy look grouse. pretty simple change over, good luck with it all.
  • Daggs
    Daggs
    real prick of a job but worth it in the end
  • Sharpy62
    Sharpy62
    Thanks for the fast replies.
    Absolutely brilliant link you sent me. I now have a job for next weekend. Would love to do it now but I am off for a ride with the missus.
    Sharpy62
