Online: binnsy, HD17, Hilly
Indicator problem
  • Mako
    Mako
    Hey guys. I just been playin with the bike in the garage and noticed  when i turn either side of the indicators (only got rear ones ) on, they both come on and dont flash. They just stay on, until i press indicator button again and they both go off. Now im tippin this may confuse poor folk following me lol. I have had a look at the wiring and come up with fuck all. Any hints on what to look for ? bad earth ? Cheers
  • Mako
    Mako
    2001 sportster. cheers
  • DynaRider
    DynaRider
    you have insufficient current draw, as you only have rear indicators
    either fit front, or get an equaliser
  • Mako
    Mako
    Thanks DynaRider. But they have been working till recently. I changed the battery thats about all ive done. ??
  • houli
    houli
    Flasher relay?
  • DynaRider
    DynaRider
    I assume self cancelling
    did you change a bulb?
    are they the original factory rear?
    do you already have an equaliser that was earthed to the battery(that you did not know about), and you accidentally left the wire off?
    when the phone rings, do you hear a car horn toot soon after? Do you ever think it might not be a coincidence?
  • Mako
    Mako
    Not self cancelling. have to press button again to cancel. They are after market lights and micro switches. Dont remember a wire i left off but i better just check. I hate electrics on bikes lol
  • clarkie
    clarkie
    flasher relay has died,in my humble opinion.
  • Mako
    Mako
    yeah LED globes. I;ll try find the flasher (lol) relay and replace it. cheers guys.
  • Mako
    Mako
    Only have rear blinkers HogBag07.
  • Mako
    Mako
    Thats plan B Bucket haha.
