Which rear shocks to buy?
  • Choco
    Choco
    Ok I hope this is the right place to ask this question in the next few months if I get a good tax return (yer I busted arse broke I own a bike enough said lol) I looking at replacing my rear shocks on my Sportster so I am seeking so infomation from you good people out there should I go Progressive or Ikon shocks and I am sorry to say it will come down to cost I know it's like asking about tyres and oils everyone has a different opinon but any feedback will be welcome cheers.
  • ireland
    ireland
    i just replaced mine with a pair of ikons ,ten times better cost $575 got them in 2 days i ride a 883 custom.
  • imoo6170
    imoo6170
    Both Progressive and Ikon are good - I have used both. The last set I purchased was Ikons, they are Australian made, can be rebuilt and are a damn good value for money shock. I rang and talked to the guy (weight, riding style, what I was after) and he advised me on what I should get. Give him a call and see what they say
    Street Address:
    81 Boronia Street
    Albury North
    New South Wales
    2640
    Telephone:  (02) 6040 9955
    http://www.ikonsuspension.com/
  • Choco
    Choco
    Looks like Ikon is the go for just under $600 for better riding comfort and we do need up here on Qld roads it's gotta be good value.
  • andij
    andij
    get some better fork springs from ikon as well and slightly heavier oil and it will all match up nicely ,dont go shorter on length though
  • speedwobble
    speedwobble
    If you get a really good tax refund have a shot at a set of Ohlins, I think you may be impressed, I know I am. Makes progressives look like second grade pogo sticks
  • Fr3d
    Fr3d
    Go for the cheapest and put them on
  • Fr3d
    Fr3d
    G'day Choco. My first response to you was a little tongue in cheek because in your initial inquiry you had already made it clear you were after the cheapest. Very rearly is the cheapest the best option. I swear by my YSS on my Road King but go on further to say that they were a premium set in their range of products. So it may be about brand, but also what particular level of product in that brand range. A high end set of Progressive is better than the bottom end set of Progressive. My advice would be to ring around the to the suppliers of the good brands and talk to them about what your requirements and expectations are.
  • Fr3d
    Fr3d
    I also appreciate the lack of money! My prioritities in customising are; braking/suspension, motor works and then bling. That is also an indication of how I prioritise my spending. Good luck with keeping it quite from the misses.
  • FastHarley
    FastHarley
    Do not look at the Ohlins if you wish to just get by and save some money.  I just finished developing these for Baggers.  I am using the F-1 race based valving in the Ressy for compression and the standard rebound adjuster at the bottom.  This is a 4"/100 mm stroke shock which is the most I can get out of a 13 1/4"/337 mm with a stroke of 3 5/8"/93 mm.  First test ride for the day as very forgiving indeed.  These shocks are not intended for the average joe's income.
  • SuperGlide
    SuperGlide
    You can get the new front and rear Burly kit and still save several bucks compared to the Ikon
    I would have to say, i've had a few different shocks on Harleys over the years, but after riding a mates FXDX that had custom built Ohlins built for him by a guy named Frank Pons. that was the best shock bar non.
    but it's like putting perfume on a pig in my opinion. the rest of the bike is not up to the same standard, so Ikon would be what i'd use.
