Changed switch blocks now headlight not working or horn help
  • nimo07sporty
    nimo07sporty
     changed the switch blocks on my bike today and now my headlight only works on high beam and the horn was working but now its not, i dont know whats happened no pinched wires etc that i can see checked fuses and i got no idea any ideas would be grateful otherwise ill have to go to the stealer and get it looked at grrr fucking pissed off simple job and now created more hassles than its worth
  • old faithful
    old faithful
    Mate,  I changed mine 3 months ago and no probs.   If you haven't already done it .... I would pull it apart again .. check for any exposed wires that may be shorting etc.  Before you reasemble, check if horn and hi/lo beam switch works before putting it all back together.    It worked before  you pulled it apart and you've checked fuses so it must something right in front of you>??   Take your time mate.  Cheers OF.
  • nimo07sporty
    nimo07sporty
    yeah checked the switches last night without the housings on and they are dead, horn dead which did work once housings were on first time and headlight still only worked on high beam so its got me stuffed switches seem ok and couldnt see any exposed wires and even if i did pinch a wire i doubt it would have been enough pressure to break a wire etc, so its rather frustrating cause im no electrician ggrrrr will check it all out again today and pull it all apart completely and re assemble and see what happens but im not expecting any results
  • old faithful
    old faithful
    Have you checked the wires for the headlight and horn to confirm if there is power in them.   If there is power there then there could be a problem with the switch's.  Are you using your original switches?  Did you change switches or just the switch covers/switch blocks?   I take it that the indicators work?
    Mate I've been down this road before myself and had to call an Auto electrician and then felt like a dickhead as I had been looking straight at the problem all the time.
    If your not sure it's probably best to have an Auto Spark  look at it   ..... be nothin' worse than than to have it playing  up later in the middle of nowhere!!
    Good luck and let us know when you find it?  O.F.
  • nimo07sporty
    nimo07sporty
    havent checked wires to headlight but should be alright i assume as the high beam still works????? i am using my original black switches only changed the housings, the indicators still work so its got me fucked hey, so next step is take it to bike shop and get them to look at it, spend even more money otherwise ill have to go to sparky and get them to look at it ggrrrr fuck alls i wanted to do is change housings and now more problems created, so OLD FAITHFUL what ended up being the problem you were staring right at?????
  • nimo07sporty
    nimo07sporty
    yeah i think ill just get it looked at by shop and see if they can fix the problem, and also a cool bundy sounds in order anyway,thanks 3737pisces, ill just relax and get it looked at the easy way
  • nimo07sporty
    nimo07sporty
    yeah went to bike shop and they suggested i look at the bulb dduuuhhh brain fart lol, should have checked it first lol oh well will let youse know if its that ha ha
  • nimo07sporty
    nimo07sporty
    fixed the bloody problem was a blown low beam in the bulb grrr ha ha thank fuck thats all it was thanks for everyone who gave me advice
