Online: B0nes
internal wiring of bars
  • Wildturkey
    Wildturkey
    can you remove pins from connectig plugs to get through bars or do you have to cut wires 07 fxst
  • Deano
    Deano
    You can remove the pins. I did it with mine. There is a page on here somewhere that shows you how.
  • AJ56
    AJ56
    Personally I think it would be easier to cut the wires and rejoin after routing them through the bars. Shrink wrap around each wire then a larger one around the lot. I removed the pins from the connectors when I done my internal wiring on my bars and in the end it was more trouble than it was worth.
  • AJ56
    AJ56
    It might be, but I had to make a tool to get the pins out of the connectors, bent a couple feeding them through. And in the end if you have a good connection and use a Ohm meter to check for continuity then there is absolutely no difference between the two methods.
  • Wildturkey
    Wildturkey
    took both harness to stealer had pins out in 5min no$
  • Sparra
    Sparra
    Here ya go...
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=4&tpage=1&view=topic&postid=11910#11910
    Cheers...Sparra
