Online: FatMat
Fogged sunnies solution
  • Burnzi
    Burnzi
    On the Nomads right to ride run I had to pull over to wipe the condensation out of my glasses. I was using the yellow ones as it was a bit dark for sunnies but they kept fogging up. Is there a home remedy or can anyone recommend a product to stop the fogging. Might be a bit of an ask as we went from really hot to really @#$%ing chilly, maybe that is a lot to do with it. Had a great day anyway
  • Soapbox2627
    Soapbox2627
    I take the sunnies down the nose about 5 mm just to get the air in behind, don't have to ride far, to help, put your head sideways (both ways)
  • flattracker
    flattracker
    I've got a product at work they reckon works well. It's called Fogtech. They're individually sealed wipes in a box. I haven't tried them though. I'll grab a couple of packs and see how they go. We also have safety glasses that come in a kit. They have a foam insert to stop the wind and you can swap the arms for a strap and swap from smoke lens to a clear lens. I use these for riding and they do a great job. Also come with arms with LED's if your working on your bike. Roughly $70 but I'd have to confirm it.
    I'll let you know how the wipes work.
  • Burnzi
    Burnzi
    Yeah mine are uglyfish, which I have used for about 6 years now. I know about spittin in my swim/dive goggles but I dont know about spittin in my sunnies. I was hoping there might be a home remedy like rubbin hot grapefruit or ur nannas blue socks or something. Thinking about buying a product designed for scuba goggles and see how it goes. Any other ideas appreciated thanx to all. Burnzi
  • Magilla
    Magilla
    Living up here in the tropics its a daily event. Every morning the glasses fog until I get moving. There is nothing on the market (although they all claim they can) to stop fogging.
    I had a site visit from the Uvex safety glasses mob from Sweeden and they cannot find a solution to glasses fogging in extreme conditions like we have up here. Walk out of an airconditioned building into 95% humidity and you can't see a thing!
    Best thing you can do is have air movement. The gaskets around the Ugly fish and the like glasses compound the problem. Air flow is the answer.......and it costs nothing!!
  • flattracker
    flattracker
    Hey Magilla,
    If you like PM me your postal address and I'll send you up a couple of the fogtech wipes. You can let me know if the do what they're suppose too.
  • dodge
    dodge
    Before you head out put a small drop of detergent (standard dish washing type) on the inside of each lense and wipe it around until it's clean. Obviously leaves a light film which for some unknown reason prevents fogging up. Works for me anyhow.
  • Cranky
    Cranky
    Till it rains and ya eyes fill up with soap lol
  • Chips
    Chips
    I bought some stuff called Monte Cristo Compound way back in the early eighties at the Sydney motor show. It was a half inch square stick of blue waxy stuff about three inches long. All you do is make a couple of lines on the back of your glasses, goggles or visor, spread it around with a tissue until the vision is clear again and it will keep every bit of mist away for a couple of days. Dunno if you can get it any more but my stick lasted me about 10 years.
  • Isaac
    Isaac
    Agree on the shampoo; locals showed me SELSUN BLUE was the anti-fog product to use on the inside of car windows during the Victorian ski season.
    Not sure why it works but it does.
