Online: speedzter
Bar Dimples
  • Sparra
    Sparra
    Just got a set of mini apes but they don't have the dimples in them to fit the wiring past the clutch and brake housing...They do have the holes for internal wiring but I wanted to fit them for awhile to see if they suit me...Has anyone tried to put the dimples into bars or do you just make the internal wiring holes longer???
    Thanks...Sparra
  • Sparra
    Sparra
    Thanks Bucket...I did give that some thought but am trying to leave them untouched but maybe it might be my only option...Other than do some internal wiring...
    Cheers...Sparra
  • stumbly1
    stumbly1
    Hey sparra,
    its a pain in the ass but I reckon just do the internal wiring thing - it takes a while but just wait for a shit day when nothing much is happening ride wise, grab a couple of ales and have at it.
    It's fiddly and can be frustrating, but like the old saying - if a jobs worth doing, its worth doing right......
    Or not. Grab a dremel a chew 'em out a bit. I did that on a set of western bars, they fit but it pretty much stuffs the look of them if you decide to go internal later.
    Cheers, stumbly
  • Sparra
    Sparra
    Thanks mate....I think thats what I will do...Had them on there to see what they where like and they are comfy and look the goods...
    Cheers...Sparra
