Online: speedzter
Trip to WA (Perth) planning in progress!
  • Dermie
    Dermie
    I have now committed myself, verbally so far, to riding to Perth on the 25th, to be in Toodjay by the 31st to a wedding (3rd wife & 3rd family @57yrs of age), he probably should have got a Harley after the 2nd set of pain. I have a few friends in Adelaide so need to stop there for at least a night & a day  & need to stop in Melrose SA, for a day. Also I think that the Ulysses club have got a AGM in Albany so I think that there may be a few two wheeled grey nomads on the road as well, any of you Uslesses??.
    As I have noticed that  a few people here have done the trip I got a few queries. I am going through the tool kit thread to sort out what I hope I will not need, but the RACVic & credit card sounds realistic. I am getting a windscreen fitted, got some panniers although they are a bit small but I am going on my own. I am considering between 450 & 700 km days, but have to put in some short days to get to Melrose from Adelaide. Then want to go down to Pt Lincoln & along the coast to Eucla.
  • PigironBob
    PigironBob
    See the following links
    www.nullarbornet.com.au/
                                         THE BIKE
    It is essential that the bike be in tip top condition and all those little jobs that you
    have been putting off must be done.           I have made a list of items to check and while
    some   people   may   consider   some   of   them   a   little   pedantic  they   are   all   included
    because   I   have   heard   of   people   having   the   problems   at   one   time   or   another. It
    cannot be stated often enough that you cannot just jump on the faithful beast that
    has   taken   you   to   the   coffee   shop   every   week   for   the   last   five   years   and   point   it
    West and hope for the best.         Well you can of course but good luck to you if you do!
        1.  Tyres need to be of  good quality, new or near  new.                 The run  is  long with
            few curves and the road surface over to the West tends to be coarser than in
            the   East.   This   combined   with   the   possible   high   temperatures   and   heavy
            loading   with   all   your   gear   and   maybe   pillion   as   well   will   have   your   tyres
            working   at   full   rating.  Make   sure   you   have   them  well   inflated   and   check
            them EVERY morning!             It goes without saying that a good puncture outfit
            and some method of reinflating a tyre is essential.             Those little bottles of gas
            are fine to reset the beads of the tyre if needed but with the size of some of
            the new tyres you would need quite a few to get the pressure back up.                     One
            of those small compressors is a good thing.             Also if you do have to use one
            of   those   wee   bottles   make   sure   the   valve   is   at   the   top   and   the   bottle   is
            pointing upward.      You want gas in that tyre not liquid!
        2.  Wheel   bearings need to be checked and  brake   pads and  fluid need to be
            new or near new.       Soggy brakes on a hot day when confronted by one of the
            lumps of potential road kill that haunt these parts are not my idea of a good
            day out!
        3.  If the bike is chain driven, then how old are the chain and sprockets? They
            must be new or near new. Oil the chain at the end of every day’s ride. If you
            have any doubts about their condition, change them.               Shaft oil to be replaced
            before you leave, let’s face it there is not much of it anyway and it is going
            to be very busy down there out of sight.            Belt drives of course need to be in
            good condition as well.
        4.  Lights   and    switches   all   OK?   That   side   stand   switch   that   played   up   last
            winter; been fixed yet?        I always spray all the fuses and relays with “Inox”
            before heading out and that way I can  forget about   it when the rain comes pouring      down.
    Carry    spare    globes    and    fuses   and    electrical   tape.     Ah
            yes…..and   don’t   forget   the   gaffer   tape!       One   little   detail   that   many   don’t
            check   is to   make sure your battery  is in  good condition and that the earth
            and   charging   system   are   tight   and   secure.        A   thorough   check   of   all   the
            electrics just before you leave is also a good idea.
  • PigironBob
    PigironBob
     5.  Now   I  know   that   this   may  sound   pedantic   but   run  the   torque   wrench  over
            everything.      Make sure all those bolts that we never go near like the brake
            calliper bolts and so on are up to the correct setting.                 I have actually heard
            of   a   brake   calliper   falling   off   on   the   Nullarbor   believe   it   or   not! Nearly
            ruined   their   day   that   one.   The   vibration   from   the   road   surface   can   loosen
            nuts and bolts.
        6.  How long since the coolant was changed?                 How long since those hoses were
            changed?       How   is   the water   pump?         I  can   go   on   forever   here,   however  I
            hope you are by now getting the message.                  Check everything and the peace
            of mind as you head out into the wide blue yonder is well worth it. It takes a
            long time to get replacement parts out there.
        7.  Trailers are a whole other area. If you planning to tow one for the first time
            have a few shake down runs before you leave and don’t overload it.                       Frankly,
            if  you  only  think   that   you   might   need   that   spare   pair  of  shoes   or  clothing;
            odds   on   you   will   not   and   can   save   the   weight.   The   rear   tyre   wear   when
            towing a trailer can be a bit of a shock too and you need to allow around a
            20% increase in wear. Check all the above applicable items on your trailer
            too.
    There will be other things that   you   may think of and   if  you do then all well and
    good and   having   fixed them  you will   have even  more peace of  mind.                     One   final
    thought, don’t put the bike into the dealers and get it serviced and plan to head off
    the   next   day   without   a   really   good   look   over   it. I   had   a   personal   experience   of
    having to leave 24 hours late because they did not complete the job correctly with
    missing  bolts   and   leaking  radiator  drain  to   mention  just  two   things.          There   were
    other things too and we were about to depart on a 11000 kilometre round trip to
    Coffs Harbour!
  • PigironBob
    PigironBob
      THE RIDER AND PILLION
    The state of health of both the rider and the pillion needs to be considered.                   I am
    not saying that you need to be as fit as Arnie to make the trip however you do need
    to   be   able   to   string   two   sentences   together   and   read   a   map.  Eyesight   is   often   a
    common problem, so, when were those glasses up dated last?                   The trip needs to be
    planned so that you are able to include rest days and allow for hot or bad weather
    along the way.
    If you are crossing all the way from the East coast it is likely that you will have all
    four seasons during your run.         Rain and wind are best left to pass however the heat
    is my main concern.        It is not unusual to use up to 6 litres of water a day or more
    each   out   there   as   the   constant   running   makes   you   dehydrate   very   quickly.   The
    effect of the wind makes your sweat evaporate without you knowing.                      One of the
    best bits of kit is the Camel Back and I strongly recommend that you get one for
    the rider and for the pillion.       Fill them the night before and put them in the fridge
    the night before, if you are able.       Keep them topped up and use them frequently.               It
    is   amazing   to   feel   the   sweat   cooling   you   as   you   take   a   swig   and   I   would   never
    travel long distance without one.
    It is of course obvious that the right personal protective gear is essential.                Stating
    the obvious I know however please make sure that you are rigged out correctly and
    you    wear    it  on  the  entire   journey.    Simple     things    like  your   medical    scripts,
    sufficient    for   the  trip,  obvious   I   know   however   I   overlooked     this   on  my   first
    journey over.     I mislaid my drugs and when I went for the spare scripts…….they
    were at home.      So it is the voice of experience!
  • PigironBob
    PigironBob
    The   distance   travelled   each   day   is   up   to   you   however   whatever   you   do   allow
    yourself plenty of time.      Make sure that you are able to have lay days on the way.                I
    normally run  for  four days and then have   a rest day.             I tried doing the run home
    from Coffs Harbour with one stop in Streaky Bay however in retrospect I should
    have   had another one.       Others   may say that is   not   necessary,   however  if  you are
    over 60 and not used to long distance riding then go on the side of caution.                    There
    are lots of things to do and see on the way over so there is no rush.
    Essentially, make sure you are hydrated, have your pills and don’t get tired.                    Also
    make sure that the pillion in a million is going well too.
  • PigironBob
    PigironBob
    In   my   view   the   journey   over   the   Nullarbor   starts   at   Port   Augusta. I   know   that
    strictly speaking  it   is regarded as Ceduna   however when  you  leave Port   Augusta
    the sign says PERTH 1900 Kms!              I forget the exact amount but it does tend to get
    your attention as you ride past!        The run to Ceduna is no problem at all as there are
    plenty of stops however accommodation does start to thin out a little as you head
    out further West.      Once clear of Ceduna you are heading out into the real crossing.
    Never pass a fuel stop without topping up fuel and your water supply.                    Nundroo is
    a spot where it is advised to keep one person watching the bike….the locals can get
    a   little   more   interested   than   I   would   like. The   fuel   is   also   Ethanol   10%   there
    however   a   top   up   will   be   no   worry   if   you   have   filled   up   to   Penong. Yalata   is
    closed   and   will   remain   so   for   the   near   future   however   the  run   from   Nundroo   to
    Nullarbor Roadhouse is well within range.               The runs between the roadhouses are
    well within the range of bikes and once again the information is on the website. If
    in doubt carry some extra fuel (say 5lt) in a specified fuel container.
    A  lot of people ask   me about the trans-continental trucks  and road trains.                  These
    guys are very likely the best drivers in the country and if you work with them they
    will  look after  you.     If  you are towing a trailer  your  maximum speed is 100 kph
    and while you may be rolling along at 100 kph sure in the knowledge that you are
    doing   100   kph   how   do   you   know   that   you   are   only   doing   96   kph?    The   short
    answer is you do not and over 10 minutes that big rig running in it’s overdrive 18th
    gear    is  slowly    catching     you,   he   is  on   cruise   control   and    I  can   assure   his
    speedometer is a lot more accurate than yours.             What to do?
    When   the   truck   is   a   couple   of   hundred   metres   behind   you   flash   with   your   turn
    indicators and wave him through.            Every time I have done this and there are heaps
    of them the truck will move right over to the right side of the road and will pass
    you  with  as   much  clearance   as   he   can.    Once   he   is   passed   and   clear,   give   him  a
    flash on your high beam and they will slowly come back to your side of the road.
    You  will  get a   flash  on the   indicators and even a blast on the air whistle and all
    returns to normal.      When they are coming the other way be prepared for the wind
    blast.  The big flat fronted rigs give you a bigger nudge than the more streamlined
    long nose rigs.     It also depends on the wind direction believe it or not.             If the wind
    is blowing from the right to the left you will get a blast, if it is blowing from the
    left to right you may not get anything. They are all using UHF radio now and some
    may even still have the old CB still working. They like a chat.
    Overtaking big rigs is a whole different ball game.              There is no way I will try and
    tell you how to do it. I will however go as far as to say watch out for the suction as
    you go past and beware of the bow wave they create as you pass the front of them.
    Enough said.
  • PigironBob
    PigironBob
    It is not a good idea to travel in large groups.  Too much dissent and arriving at a
    servo on the Nullarbor with 20 bikes will mean that it will take ages to refill and
    get going again.
    As I have already said this is a guide for those who those who are not used to long
    distance riding and who are starting to not buy unripe fruit.   This is not necessarily
    directed at those who are used to reeling off 700 kilometre days one after the other.
    Enjoy the trip, it is huge fun and is not hard to do as long as you take it easy, take
    proper care of yourself and relax.
    My $.02 worth
  • Nightrider
    Nightrider
    Wow what agreat trip it will be.
    I was planning to do it for my birthday at the same time but work has posted me to sydney.
    I have only ever driven the nullabor several car trips and a few truck trips.
    Just wanted to add get your riding done before dusk starts to set in Skippies are plentiful and like to cross the road.
    some stretches are free of them but the last thing you want is to be dodging roos. I know its obvious but i thought id say it any how.
    The run along the south coast is definitely nicer than norseman to toodyay.
    watch out for the cops out along the nullabor they are fast and love to nab speeders i got done out there a few years back.
    thanks also to Pigironbob. i have been looking at this trip for a while all your info is gold mate.
    A few weeks ago a dude came into my shop was gearing up to do a run across on a postie bike!!
    Balls is all i can say :)
    have a great time let us know how you go. :)
